hellp
paul272
Hellp my router keeps dropping out and i have to re set it every time every 20 mins
Northerner
Hi @paul272
Fixed line broadband or mobile broadband.
Which router do you own.
manatarms84
Expert Contributor
Expert Contributor
 I would check all your wiring to make sure there are no loose connections.  Then I would power everything down for 3 minutes to refresh everything.  If the issue persists I would call technical or request a call back by texting GUIDE to 61998 to check for any faults on the line
It's 66033 now.
