on 04-11-2025 02:41 PM
ive just got my bill through and it says im being moved plans, its the first i've heard of it and my account says my plan is ceased.
should i just hope my plan switches or is this some weird error?
Solved! Go to Solution.
on 06-11-2025 09:17 AM
I'd recommend giving our customer service guides a call, and they can bring up your account and see exactly what is changing and to what, and how it will impact you.
Michael
04-11-2025 03:26 PM - edited 04-11-2025 03:27 PM
What is the name of the EE BB plan are you on now including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
on 04-11-2025 04:27 PM
hey, i was/am on Fibre Plus without landline and a smart hub plus router
on 04-11-2025 04:31 PM
What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker.
on 04-11-2025 04:53 PM
04-11-2025 05:02 PM - edited 04-11-2025 05:04 PM
Yes, EE are probably moving you to Full Fibre (WBC FTTP) from FTTC VDSL. It will require a new connection to your house.
Would you now post the text below that table so as to see how difficult it might be or not?
on 04-11-2025 05:20 PM
04-11-2025 05:47 PM - edited 04-11-2025 05:53 PM
Good, you'll get your new fibre line from the nearly telephone pole (as you do now). There should be no difficulty.
Oh, I just noticed it says "ONT exists with active service". That should mean you have a full fibre box on an inside wall with active Full Fibre. But EE Fibre Plus is not Full Fibre.
on 04-11-2025 05:57 PM
EE Fibre Plus also wouldn't provide an EE Smart Hub Plus as claimed in the post, it's a Legacy EE package.
on 04-11-2025 06:13 PM
So my plan will swap automatically? its strange because ive not seen anything off them about this until this bill came through
