10-04-2025 08:37 PM
Our WiFi keeps dropping it's connection multiple times a day. If we switch it off and back on it usually comes back on. The lights on the router remain blue and we have not changed it's position. Any advice?
JS
10-04-2025 08:54 PM
@Janices not much information there to go on.
What broadband service, what router, is it just WiFi that has problems?
Have you considered using the Help section to check on your service?
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
150
0330 123 1105
To use the text relay service from your smartphone, PC or tablet, download the free Relay UK app.
To call us through the Relay UK app or from a textphone, dial:
18001 07953 966 150
If you need the support of a British Sign Language (BSL) interpreter, you can contact us through the InterpretersLive! service.
10-04-2025 08:54 PM
Opening hours:
150
0330 123 1105
18001 07953 966 150
