Using Smart Hub as a wifi extender
mistertomonline
Hi I am struggling to configure my old Smarthub as a wifi extender for my new smart hub plus.
I tried this previously with different equipment and had similar issues... I've tried following all the different guides I've found including those posted by @XRaySpeX  but not got anything working even with this newer kit.
Principally I have done the following:
Hooked up new smart router plus. All working fine.
Connected laptop via ethernet to old Smarthub. Configured IP address as 192.168.1.198
Subnet left as 255.255.255.0
DCHP server off
Given Secondary SmartHub a different name and password so I can clarify it is working.
Connect Primary SmartHubPlus LAN port to Secondary SmartHub WAN port by Ethernet cable
Devices can see the 'Boost Smart' Hub, but no internet if I connect.
Really could do with some instruction here! Don't see what I am doing wrong!
(Also, when I changed the IP address to 192.168.1.198 my laptop abruptly couldn't find it and the router settings page disappeared, even though it was connected via ethernet cable. Is this normal, or show Ive made a mistake somewhere?)
Kind thanks,
Tom
12 REPLIES 12
If you are connecting the WAN port of the Secondary SH to the LAN port of the main SH+ (by presumably following Re: To make a second Brightbox as a WAP on your LAN to the main Brightbox) to make it act as a further router you should keep its DCHP server ON with a Range on a diff subnet from that of Primary router..
You only keep the Secondary router's DCHP server OFF when you are having it act as a WAP with it being connected by 1 of its LAN port (as in To make a second Brightbox as a WAP on your LAN to the main Brightbox).
Community Hero
Community Hero
@mistertomonline Lan to Lan connection for devices, NO Wan to Lan port connection at ALL!
@JimM11: But LAN to WAN is OK! 😉
mistertomonline
Thanks for the rapid reply both!
In both instructions it says
  • Connect Primary BB LAN port to Secondary BB WAN port by Ethernet cable -
So I was a little confused!
I have now attached LAN to LAN...  still no connection
The following I cannot find in the router settings:
  • Set Broadband Type of Secondary BB = Fibre/Ethernet for a BB1 or Ethernet for a BB2 (untick the "Enable ADSL/Fibre auto sensing" 1st), under Basic Settings.
  • Set Protocol of Secondary BB = Bridging, under Basic Settings.
  • Disable NAT on Secondary BB.
  • Reserve the Secondary BB's Gateway IP Addy in the DHCP of the Primary BB.
In the instructions for a WAP it should be LAN to LAN.
The 1st 3 of those router settings are only applicable for a BrightBox. Ignore them for a SH.
In My Network of the Primary SH+ you should see an entry for the Secondary router.  You should make it as "Always use this IP".
mistertomonline
Thanks, still having trouble though.
I have the secondary SHub connected directly LAN to LAN to the main hub, I cannot see it in the network as an ethernet connection. I connected my laptop directly to the LAN and can see this as an ethernet connection in the network s...
There is a wireless connection to  'ET0021B7BF2A33' which has 0kb traffic up and down, as it seemed to stay there and not disappear, I presumed this is my router and not one of my sonos speakers.  I have set "always use this IP", and set the IP address to 192.168.1.198
However I just checked the back of the secondary router and its mac address is different, and Ive not seen it at any point.
Still no connection... any ideas why I might not see the secondary router show up at all?
mistertomonline
Tried resetting the secondary router and keeping the IP as 192.168.1.254 and still cannot see it. However when navigating through the hub manager options it occasionally tries to connect to the new Smart Hub plus, (which I can tell because it keeps asking for a password and they are different for each device)  Even though my laptop is only connected via ethernet to the secondary hub with the wifi turned off, so they MUST be connected in some fashion...
It's not the router. MAC 00:21:B7:BF:2A:33 belongs to Lexmark. Is that your printer?
Routers don't ask for each others' pwds.
