Uploading issues
IFC1
I had Fibre to the Property installed about 10 days ago. Whenever trying to upload a large file (80MB) the broadband connection is lost. I have had 2 successful uploads at the expected speeds, otherwise it is painful with broadband disconnecting maybe 2 or 3 times during each upload.
Any ideas why this is happening? It is worse performance than with copper wire with BT.
Maestro
Maestro
@IFC1 What router do you have, and what package of FF did you get? An 80MB file is not very big in terms of size, so uploading should not be much of a issue. You may also mention wither testing is pure wireless or ethernet network connected.
Here is a speed test for you, have a close look at the upload side to see if problematic with that area.
https://speed.cloudflare.com/
