Split (broadband) bands when using new EE black box to run devices
CathOLeary
If I have the new black box, can I split the band into 2.4ghz and 5ghz?
Thank you.
No, not with the Smart Hub Plus. Best you can do is temporarily disable the 5 GHz band while connecting problematic 2.4 GHz devices.
Thank you.
How do you temporarily disable 5ghz? ....there is no switch on my new Smart Hub
@terryrmm : Try on the Advanced Settings > Wireless page to temporarily disable the 5 GHz WiFi band & move off the Smart channel while connecting problematic 2.4 GHz devices.
