08-07-2022 01:25 PM
Hello,
In the past we had the 64MB/s plan or something similar to that, we upgraded our speed to 144~ or around, the new modem and technician arrived and been setup, but we are still getting the old speed.
What is the cause of this?
08-07-2022 01:28 PM - edited 08-07-2022 01:31 PM
08-07-2022 01:35 PM
@pulsy how’s your activation for your new tariff started yet ? When was your start date due this new tariff? You should of got an email with the start date if that date has passed you might want to call customer services to make sure your new tariff has started.
