Raising a complaint
Badger011
I am having nothing but trouble with my EE broadband. The signal keeps dropping, cutting out, is almost always weak even with a hard connection. I've done ALL the trouble shooting for the HUB, I've checked all the ports etc. This has happened before and they did nothing. All I want to do is talk to someone about it and raise a complaint. They keep putting the cost of my bill up yet I can't use it! I have the extra discs round the house, used the app to make sure they are in the perfect spot too. I only have min 3 devices hooked up at once with a max of 5.
@Badger011 : Welcome to EE's Home Broadband Forum.
@Badger011 : You can make a formal complaint to EE & if you don't get satisfaction after 8 weeks you can take it to EE's ADR provider. See Complaints code of practice and here is the Complaints Form at the foot of the page.
