Problem accessing an important website
Pterosaur54
Having just moved to EE from Virginmedia, I am finding that I cannot load the home page for my Hostpresto web account.  It always returns protocol error.
I have pinged the site and traced the connections, Hostpresto have done the same from their end.  The connection fails at the return in the modem. EE have reset the modem to factory condition remotely and that has not solved the problem.
The setup came with no instructions and no directions to a user manual, so my question is, how do I access a hub user manual to enable me to resolve this issue myself?
The EE helpline is a 2 hour wait away, and I have a life to live.  Apparently I have a question started badge now!
22 REPLIES 22
@Pterosaur54 Certain things can be done using the web Interface, others need to be done via the app, and checking if web protect is on/off needs the app, so if you don't get the stupid app in a working condition, ride out your remainder off the term best you can, it's the EE way your caught now. Raise a complaint may just get you released and back to VM you can go.
All Pterosaur54's Badges - The EE Community
Added.
Are you even getting to here?Are you even getting to here?
Pterosaur54
Yes I am getting to there.  The problem is simple, the return is not getting to me.  It is probably a simple solution to solving the connectivity, but I cannot find the causal point.  Everything works as normal when my hub is not part of then equation.
@JimM11 ........."Raise a complaint may just get you released and back to VM you can go."
Not my best choice.  VM is considerably worse than EE in many respects.
I think my next action will be to update my smartphone to make sure I can access the app correctly.  We are currently on an old dual phone account, which may be an issue with the hub. There must be a way of working through this mess-up.  In reality, whichever way I go, the modern way of service provider operations is going to be the main obstacle until I master the system, which is very different to the one I cut my teeth on in 1983.
@Pterosaur54 The secondhand used BT Smart Hub 2 may be the way to go for you, not a smart phone needed at all for it, plenty going about on Flea Bay around the £10 mark.
