Printer fail is this 5gt problem
Cle2
Sometimes older or weaker devices may not be compatible with the default WiFi settings of EE Smart Hubs with their WPA3 Security. Try setting up Compatible WiFi on the router under Advanced > Wireless Settings > Config > Compatible WiFi (it defaults to 2.4 GHz only & WPA2) & connect your problematic 2.4 GHz or WPA2 devices to that. It presents itself as a separate network SSID of the form "MainSSID-Comp".
Schockwave
Hello @Cle2 ,
Welcome to the community,
If it is an older printer, you may have to go and click on compatability via settings for your broadband and try connecting with 4Ghz rather than 5Ghz, this can happen with some devices that are not compatible with 5Ghz.
@Schockwave : You mean 2.4 GHz not 4 GHz.
@XRaySpeX , yes that is what I meant, you are correct.
