Printer connection
Ibartdeco51
I’ve recently moved from VM to EE do I need to reset/pairup my printer with EE if so how do I do this?
@Ibartdeco51  Yes you do and if the printer has a WPS button you press the WPS button on tne side of the router and then WPS button on the printer.  It’ll then pair up itself
Hi
Thanks for that.
Tried as suggested still no go I have a HP printer 3760 is a few years old maybe it’s developed a fault any other suggestions?
Les
Sent from my iPad
