31-10-2022 05:06 PM
Hi, does anyone have any experience with port forwarding? Don’t seem to be able to save a new rule or protocol, just doesn’t save, not sure if I have a setting wrong elsewhere which is preventing this?
any help please!
31-10-2022 05:13 PM
Yes, I have. Show us the page you are trying to save.
31-10-2022 06:28 PM
31-10-2022 06:41 PM
Use the Camera icon above your text to upload an image file to here.
31-10-2022 06:43 PM
31-10-2022 07:01 PM
There's nowt there!
01-11-2022 08:04 AM
Posted in the open:
@Psell wrote:
01-11-2022 08:06 AM
It's not much use w/out the port forwards filled in.
01-11-2022 08:38 AM
Posted in the open:
@Psell wrote:
Have a range of port forward No’s, nor sure which to use.
Background, I have a gate intercom and since switching broadband from Sky to EE I am not receiving notifications to my I phone, have spent a couple of hours on the phone with the intercom manufacturers tech team to eliminate a hardware fault, all good no faults. They say it can only be a closed port causing it, they think 443, but have given me a range of others to try 80/10002/10005/13140/8600, as you can imagine I have no idea which to use and in which combination, spoken with EE so called technical help, they have no idea and don’t have a level two technical dept for broadband.
01-11-2022 09:35 AM - edited 01-11-2022 10:09 AM
If you don't know what ports need forwarding & the device manufacturer doesn't either, we can't tell you what they should be. EE block no outgoing ports. Port forwarding is only needed for unsolicited access to incoming ports. I would say:
All the same, show me the Port Forwarding page filled in with what you tried but it wouldn't Save.
