01-12-2025 07:16 PM
Ive contacted EE on at least 3 occasions as my devices cannot stream something as simple as my EE TV or netflix etc without dropping out every 5 minutes.
Every time I get through to EE they check my speed (as I do myself) and confirm the speed is showing as fine / more than capable of streaming. Go through the usual rebooting and resets. Ive even been set a new hub before.
If it does fix, its for a week before its back to how it was.
To stream anything currently I have to hotspot to my mobile.
Quite frankly frustrated by the lack of support and investigation into my issue.
01-12-2025 07:50 PM
What is the name of the EE BB plan you are on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
01-12-2025 07:56 PM
Essential Fibre 67 - no WiFi extenders as in a small 1 bedroom apartment.
Hub is the newer smart Hub
01-12-2025 07:59 PM
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
01-12-2025 08:08 PM
