POE Access Points not connecting
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-03-2024 05:52 PM
Hi - I have just moved from BT Hub to the new EE hub. I have connected 2 POE Access Points (Ubiquiti) but cannot get anything to connect to them. I have factory reset the APs and know they are working as I can see them when searching for WiFi but they just hang when trying to connect anything to them. When I go into admin it shows nothing connected to Ethernet ports - does anyone have any suggestions of how to fix? Many thanks.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-03-2024 09:42 PM - edited 16-03-2024 09:43 PM
@pgc123 not really sure what you mean. Or know much about your Access points - are they expecting POE from the router or do you have some kind of adapter?
Which admin are you going into - the router or the AP?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-03-2024 11:19 PM
If I look at available WiFi I settings on my mobile phone I can see both APs named but cannot connect anything to them.
When I log into EE router it is showing no Ethernet connected to any of its ports. Either the ports are not working or I think I need to do something with the EE admin settings?
Sent from my iPhone
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
07-10-2024 04:04 PM
I am having the exact same issue. Never had an issue for years with this AP and suddenly I switch to EE and it stops working.
