Only 26mph signal and Norton is slowing laptop down
PembsLady
Although I live in a beautiful area the speed of the internet is shocking. The maximum I can receive is 32 to the router and 22 to my laptop . I'm struggling to work as its even slower as apparently Norton is using too much and slowing down my laptop even more.  The open reach engineer has been our and has confirmed as the house is very old they've split the signal so I can get internet in my work room, but because of the virus checker I'm stuck. I left BT because of cost, but to be honest I would go back to them in a heart beat as this is unworkable. Any suggestions please? I'm not tech savy at all! I wonder if I should just take my laptop to a computer shop and ask them to delete Norton. Although its free with EE it's a big problem (I didn't have any problems with BT Mcfee ) Any suggestions would be appreciated, as suggested by EE as they haven't got any idea how to help. Many thanks
