Notification of intending direct debit much higher than expected and worrying
Stewartjacqueli
Maestro
Maestro
@Stewartjacqueli Check you e-mails for what and 1st bill may be slightly higher than expected for postage cost's, if not that and you are looking at the billing, for the 1st 3 months it get's all out off whack, so £30 looks like £60 then £90, they only ever take the £30 that is due but if you are worried you do need to call EE CS to confirm, if it is anything to do with landline calls then the per minute charge if you do not have a call package is extortionate to say the least! The Forum is public and customer response. Number if you need to contact is below in the link information.
Contact Us | Help & Support | EE
Maestro
Maestro
