My ee WiFi box shut down without warning…won’t switch on
MamaDerek
Northerner
Hi @MamaDerek
Mobile or landline broadband router.
Maestro
Maestro
@MamaDerek If you have tried with it plugged into another known good power socket then either the PSU unit or the Actual EE/BT Router has failed not ON/no light Indication. You will have to call EE/BT CS to order a replacement unit. Although you mention EE in your posting heading you could have either off the Routers supplied, and just the EE contact us below.
Contact Us To Request Technical Support for Broadband and Landline | EE
