Moved from BT to EE
Al3ee
At the suggestion of BT I moved over to the EE platform. I was explicitly told that I would get a new router and it was all simple and painless. I have obviously paid EE for the privilege of doing so. However, two days after the transfer and having received several emails about how easy it all is - I find that I have no landline. The old router is just flashing red.
What have I done wrong? Apart from swapping from BT to EE! Why am I not able to use my landline? Any thoughts - because EE cant help me until Sunday afternoon!
12 REPLIES 12
Totally agree with you.
It may be one name but they definitely behave like dealing with seperate companies.
I’m just in the process of drafting a complaint to the regulatory bodies after reading the codes of practice the call handlers I’ve dealt with when raising a complaint have not even followed their own policies so what hope does anyone have of fixing such problems.
Profile closed
Not applicable
@Nathanvtr
Good luck.
I know these sorts of user forums can give a skewed impression, but posts here suggest, in no particular order:
*Indifference from the Executive
*Insufficient resourcing in staff numbers
*Cutting back on “contact us” options to favour 150, resulting in lengthy on hold times.
*Too many tasks requiring manual intervention ie someone has to *do* something for the process to work. It isn’t done, or is done wrongly. Whether this is due to insufficient staff or inadequate training I don’t know.
*Key details omitted in calls eg I wasn’t told my SIMs would be speed capped, nor that my NF would now be subject to ads.
*Poor system design eg order placed, money taken, order confirmed - then cancelled by txt with no explanation why, or when the pymt will be refunded.
Etc. For my part, each element works, even if the account functionality isn’t what I had w BT. So I’m going to leave it the hell alone. Life’s too short 🤷🏼
@Al3ee Are you still on the BT Router that you had before the BT to EE move?
