Misadvising clients without the appropriate renumeration
JCC93
Lets discuss a real life scenario: You wait over 45 minutes on the phone because your broadband suddenly ceased to work, despite this no matter how stressed you are, you are polite, friendly and understanding. You get told to fix a problem by "just buying a new power supply from an electrical store" and still have to also wait for the appropriate one from EE to arrive on the post. As per the advice given as you're desperate to have internet, you go to the electrical store and buy said power supply. The power supply is in perfect working order, but your hub still doesn't work, all of a sudden you're confused as per the advice from the agent you thought you fixed the problem. Not the case. You call up and get told you were misadvised and also now need a router. You express your disappointment and dissatisfaction. You wasted your fuel, your time, you could not work as you were out of internet and now out of pocket. You get told "cannot compensate because you went to shop and bought one, maybe get a gesture of goodwill". As a customer of over 11 years with multiple lines and broadband, that hurts, makes you feel short changed and just left with a sour taste. Don't worry though, the manager will "give you a call" Monday morning to discuss.
To add Insult to injury, you also at one point even sold EE products and services for a period of over 2 years.
20 REPLIES 20
@Fedup500 Do you have an actual problem or good and working currently?
Fedup500
No internet currently for a week. I've been told 4 times now that a new hub will be put on order (as the previous person hadn't completed the order) , it's now got a delay on processing this order again so unsure how long until I will receive this. They did an upgrade a week ago incase it was that that caused the fault so I have now used a week into my 14days cooling off to cancel and no further on. Just seeing if it's worth changing provider
Fedup500
Also to add that every time I speak too someone they say different things - it's not the hub / it is the hub . You need an engineer / no you don't need an engineer
@Fedup500 Sorry confused, if you have never been activated then your contract has not started. You will not be able to transfer to anyone OTS wise for at least 14-21days currently unless OR are quiet and can get to it.
You have not posted anything, can the Forum help with anything advise wise for you, if so detail is required.
Fedup500
I am already EE , phoned to fix a fault . Told it's not a fault, I need a new hub. Then no the hubs fine it's a fault.  Then hub has been ordered (4x) but order never completed each time. Hopefully this time it has actually been processed. Yer the guy today said that cooling off period to be able too cancel within has already started so only have 2weeks left to hopefully receive a hub try it and get an engineer if fault still present
@Fedup500 What hub is it you have, there is currently a FW update that happened three weeks ago messing with two off the EE Hubs, the 7Pro and the 6Plus? Below the link shows the current EE ones.
Fedup500
It's the old smart hub style. I think the frustrating part is why am I not being updated , why am I being told the previous person didn't order , one minute I need an engineer the next I don't. It's so confusing and I've never had an issue with EE before.
Fedup500
Nope I think older than that - its about 3years old . White
@Fedup500 Will be the smart router version, so lot older than 3 years, that one above was from 2021.....
