01-08-2022 07:02 PM
Hey, on the 20th of July, I started a 12 month contract with TalkTalk, they messed up something with their system and I wasn't able to upgrade to fibre. Therefore, while being in the middle of a TalkTalk contract, I decided to order the Fibre Plus contract from EE. Will EE cancel the contract with TalkTalk, making me pay for the months that are left or do I cancel the contract with TalkTalk myself? Thanks.
01-08-2022 07:13 PM - edited 01-08-2022 07:17 PM
Yes, EE & OR between them will get your TT a/c closed as long as you are migrating the same landline no. EE will take care of everything bar your final bill.
01-08-2022 10:06 PM
@Faizan_99 Are you sure it was a problem with their system, and not a capacity problem at the cabinet?
Try putting your number in the BTW DSL checker, post the results hiding your number.
https://www.broadbandchecker.btwholesale.com/#/ADSL
Beware you are likely to get early termination charges from TT.
