Is there a way you can reboot my rooter remotely?
davidharwood55
I have had to reset my router evey couple of days recently.   I assume it has a problem on the 2g  at the moment as my ring camera had gone off again.   I am on holiday and it would be helpful to get it working again.
@davidharwood55  that’s not possible.
9 REPLIES 9
Georgeoustar
I just managed to reset my router using the EE app
@Georgeoustar  at the time when this was answered it wasn’t possible it now is.
How?
Katie_J
Hi @Ludoz1
Do you have access to the EE app?
Katie
Yes
Katie_J
Hi @Ludoz1
Are you able to view Hub Manager?
Hub Manager is where you will find your hub settings and where you can restart your hub, change your WiFi password and test your connection.
Katie
I know this and I have done the reset before but you have to be in the reach of your WiFi. If you are not close to that I was wondering if it is possible to reset it over www.
@Ludoz1  What router do you have ?  Can you post a picture of it.
