Individual upload connections are limited to 1Mbps, but speed test is 8Mbps
CorporalClegg
I noticed my Dropbox uploads were slow, so I did some digging. I have a couple of tools that show me the upload speed for each connected service. Although my line tests at ~8Mbps (via an online tool, or direct from the router's built-in test), no service is able to achieve an Internet connection above 1Mbps via my EE broadband. It's not a WLAN or LAN issue: it's as if the WAN is throttled to 1Mbps per connection – although I don't know how the speed test connection gets round that? Specifically, I've also tested upload via the hotspot on my phone; here Dropbox (etc) are getting over 2Mbps, so any throttling is external to my computer.
I've also tried connecting to Dropbox via a VPN. Again, the VPN connection itself is only achieving a throughput of 1Mbps (although it still tests close to the 8Mbps via an online speed checker). Perhaps the VPN service is also on a list of speed-limited services for EE?
Is there a fundamental disconnect between test results and actual upload speeds that I've not understood? Is it a feature of EE broadband that it's actually only 1Mbps up for practical use, even if it tests faster? Is there a clever test I can run to demonstrate that various services / connections are indeed being speed limited?
Thanks.
12 REPLIES 12
I'm not entirely sure why any of this is relevant to the question I asked, as the problem is not about the apparent speed of the upload according to speed tests, etc, but the real world upload achieved by services such as Dropbox…? Anyway, speed test is built into the router and always shows upload speeds much higher than those achieved by actual services rather than speed tests. It is not a WLAN issue.
I've also turned off the parental controls to no avail, in case Circle (bundled with Netgear router) was applying speed limits. There are no QoS or bandwidth management controls that I can access on my router.
Just trying to understand what you are getting at in terms that I am familiar with. Now I can see.
Your actual speeds are at the bottom of the expected range for VDSL anyway.
I would just say that the Dropbox server is just busy with others to give you your full upstream speed.
Well, er, thanks, but no. As I said, Dropbox is not the only service affected – VPN is also throttled to 1Mbps. Also, Dropbox speed jumps up immediately if I connect via the phone rather than the EE broadband. Something is throttling my broadband Internet connection in some way that is not detected by the speed tests. I am not sure how to tell if it's per service or overall, as there's also LAN traffic popping up on the NIC so its overall speed is often higher than just the Internet connections.
If I could see the router's connection stats I might be able to say more.
I sent the router connection statistics.
If you mean your 2nd image, that's not what I'd call router connection stats. They would have Up & Downstream connection (sync) speeds, Attenuations, Noise Margins (SNRM), Error rates, ... Anyway I can't imagine such a slow WAN upload speed of 135 Bytes/Sec.
bobpullen
Scholarly Contributor
@CorporalClegg - do you have an EE-supplied router you can test with?
Are you able to replicate this problem across more than one connected device, or is it isolated to a single computer?
Mustrum
Or the connection stats from the modem you are using - rather than the seperate router that you appear to have.
