Hub 6 static IP
Darren4466
I need to set a static IP address for a device on my network. I can log into the Hub 6 and set it to alway use at static address and set the address but it will not save the changes ? I have done this previously on this Hub with out issue ?
bobpullen
What happens when you try saving the changes? What device are you wanting to set a static IP for? You might be able to do it on the device itself, rather than relying on the hub.
