How to connect Linksys Velop Nodes es WiFi extenders/boosters to my EE SmartHub
nishvc
I have just installed EE wifi in the house and have some Linksys Velop nodes which I would like to use as boosters/extenders.
1. Is this possible
2. If so please can someone tell me how to do this.
1 ACCEPTED SOLUTION
Mustrum
@nishvc   then just follow the info from Linsys - connect the first device WAN port to an EE Lan port. Use the app to add your other device to the network.
https://support.linksys.com/kb/article/120-en/
Mustrum
@nishvc   you don't say if you are on Full Fibre or not. If so, the easiest way is to do away with the EE Smart Hub and set up the Velup as per the following Help page https://ee.co.uk/help/broadband/getting-started/using-and-configuring-a-third-party-router
If however you are on FTTC and or have Digital Voice or TV then you could set the first as an Access point.
Hi Mustrum,
I'm quite sure that I have FTTC
Mustrum
