Hi I'm looking at joining ee, which hub for Fibre 50 essentials (pic & spec)?
slf3
Probably the EE Smart Hub Plus to be seen in Compare our Range of Broadband Hubs unless you are coming from BT when you will be required to keep your BT Smart Hub 2.
The EE Smart Hub Plus has a 2.5 Gig WAN, 4 x 1 Gig LAN ports & WiFi6.
