21-07-2026 10:21 PM
1 Bot says line is fine for months. Associate says they will improve my lot and dupe me into buying an I phone. Cancelled when bill clarified the dupe.
2 Engineering change all equipment and add booster
Achieved below 10MBPS at peak times.
3 Engineers finally say it’s the 50 year old copper connection 300 meters of.
4 try 4 g hub and lots of contract changes. Lasted one night 0 to 2 bars drops signal constantly.
5 Try to contact again and keep the poor MBPS contracted for min 19 get as low as 5.
So hopefully ee will compensate me for poor service I have had for years. Reduce my bill which the 4 g hub would have but it’s worse than 50;year old copper.
21-07-2026 10:38 PM - edited 21-07-2026 10:40 PM
@evansnj34 Call EE CS but it's not going to happen for you getting money back, are you ADSL or VDSL connected if you know? you can look up and post back hiding details if you want, just use building number and your postcode, will link a sample if you wish to look at it also.
Re: Hot and cold messages from EE/openreach is this usual? - The EE Community
21-07-2026 11:57 PM
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
