EE internet speed
kevin904
For quite a few years I have had a stable 36Mbps internet speed. Latley, I have noticed that my internet speed was very slow and had cause to complain to EE . To be fair they soon had the issue all sorted and my internet speed was back up at what Id been having for some time 36 Mbps
Today I couldn't get any internet at all and after some time the internet  returned but at a much lower speed, I have now only got 31Mbps speed , a drop of 5- 6 Mbps  Are EE lowering the internet speeds they are offering to their customers, Ive been on their website and have noticed that they are now advertising max speed of only 31Mbps
What's happening , can anyone help
No, EE are still advertising the Fibre BB package that you have as an average speed of 36 Meg. This is almost an industry standard.
Mustrum
@kevin904   the answer and reason your internet has slowed is more likely your phone line had developed a fault or has become noisy. .  Over time the weather can get into joints nd cause corrosion, and a simple cheap corded phone can be used to listen for noise. You can dial 17070 option 2 and listen for it.
HTH.
