EE SMART HUB 2 change to third party due to upload lag
Brownc1
Can someone to the love of god help me?
I have been moved from bt to ee and the upload lag ping for gaming is like 3k jitter.
i am wanting to try fix this by getting new third party hub but unsurprisingly ee hub isn’t great to do this and will get double Nat?
Can anyone help
81 REPLIES 81
I can’t do that test on my ps5?
however I can turn off all devices apart from my ps5?
my socket is master socket 5c?
Unless you have DV you can use any DSL modem router instead of the SH (2023) w/out causing a double NAT..
What’s a dv?
Thing is I don’t know how to set up
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Only if you have an active landline, try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket using a DSL dangly micro-filter. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
DV = Digital Voice, the EE replacement for traditional landlines.
Chat gpt has said you’re wrong.
Since you have EE FTTP with a Master Socket 5c, a DSL modem router won’t work. FTTP uses fiber, not DSL, so you need either:
  • EE Smart Hub for FTTP (with XR1000 behind it)
  • A PPPoE-capable router connected to the EE Smart Hub in DMZ/IP Passthrough
In short: DSL modem routers are for copper/fiber-to-DSL setups, not full fiber.
@Brownc1 Would need to go back find but i know a OP used this and got connected with no problems, will take a look latter and link the post when i find it!
Archer VX1800v | AX1800 Dual-Band Wi-Fi 6 VDSL/ADSL Modem Router | TP-Link United Kingdom
was away back 18 months ago but this is the linked post below!
Solved: Wifi Hub disconnecting every 10 minutes - The EE Community
Given that you said you have FTTP (Master Socket 5c) with EE, here are the compatibility issues:
The Archer VX1800v’s primary interface is DSL (RJ-11) for VDSL/ADSL. Its “WAN via Ethernet” ability is mentioned, but the main design is as a DSL-modem-router.  For an FTTP connection with EE, you typically don’t have a DSL line – you have fibre to the home with an ONT (optical network terminal) and then an Ethernet WAN to the router.While the Archer lets you use its Gigabit LAN/WAN port to connect via Ethernet (so in theory you could use it as a router only), using it to replace the EE Smart Hub completely may still run into issues: double NAT, FTTP authentication, or EE’s proprietary features (VoIP, TV, etc).Because EE’s Smart Hub for FTTP doesn’t support full bridge mode (as you mentioned earlier), connecting a third-party router still typically means you’ll end up behind the EE hub’s NAT unless you use tricks like DMZ/passthrough.
Is this true mate? Really not a tech guy and don’t want to waste my time getting my hopes up
Master phone sockets 5C cannot deliver FTTP. They deliver FTTC which is DSL partial fibre / copper. FTTP needs an ONT not a phone socket.
If you had Full Fibre (FTTP) your EE BB plan would be called "Essentials Full Fibre 67" not "Essentials Fibre 67".
Look at the LH wall of the below image (my set up):
You have the nearer box, probably flatter, a Master Socket 5C, which is only for FTTC.
The further box, an ONT, is only for FTTP (Full Fibre).
