E
Spaceman-
I just upgraded to 500 core a few days ago, and every time I've done a speed test, it's around the 180-210 mbps mark
The same speed i was already getting before i upgraded, is there a problem or does it take a few days for the router to update?
bobpullen
Star Contributor
Star Contributor
What speed test are you using/how are you testing? The EE App has a speedtest that runs directly to your hub and would rule out any device capability/WiFi limitations. Nothing needs changing in the router so as long as the upgrade order is complete then you should be getting the faster speeds.
Can't hurt to try rebooting your Openreach ONT too if you haven't tried that already.
