Download Speed
UtilityFraud
A few months ago I switched to fibre. Initially I was getting approx 2-3MB.
This has now dropped to approx. 400kB.
If I run speed tests it shows speeds that I am just not getting wherever I try to download from.
Tried sending HELP to the contact number and have heard nothing yet.
Been like this for about 6 days now. Near useless.
9 REPLIES 9
UtilityFraud
Further details: I am using the EE hub and all connections are wired. Wireless is turned off.
This is a list of your EE Smart Hub settings and current statistics
Product name:Smart Hub
Serial number:
Firmware version:v0.06.01.08190-EE
Firmware updated:Your Firmware has not been updated.
Board version:01
DSL uptime:0 Days, 3 Hours, 3 Mins, 2 Secs
Data rate:801.00 Kbps / 5.20 Mbps
Maximum data rate:22.20 Mbps / 84.89 Mbps
Noise margin (up/down):23.4 / 33.3
Line attenuation (up/down):13.4 / 12.8
Signal attenuation (up/down):15.6 / 12.8
Data sent / received:302.4 MB / 6.4 GB
Broadband username:
2.4 GHz wireless network name:EE-Hub-JSf4
2.4 GHz wireless channel:Smart (Channel 1)
5 GHz wireless network name:EE-Hub-JSf4
5 GHz wireless channel:Smart (Channel 36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:
Software variant:
Boot loader: 0.0.3-EE (Mon Dec 4 17:32:53 2017)
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean) UtilityFraud_21-1661955297577.gif
8067.3201960AvailableAvailable--
8064.32018.855AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33050--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 17.5--16 to 19.5AvailableYes
Up to 17.5Up to 1.516 to 19.5AvailableYes
Up to 8--7 to 8Available--
2----AvailableYes
2----Available--
SOADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) WBC SOADSL Availability Date Left in JumperWBC SOADSL 2+SOADSL MaxSOADSL Fixed Rate
Up to 17.5--16 to 19.5--Yes
Up to 8--16 to 19.5----
Up to 2--7 to 8--Yes
Observed Speeds VDSL ADSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
6.3923.07
0.81.17
2022-08-282021-07-22
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
N
N
02-07-2022
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
The exchange is not in a current fibre priority programme
WLR is currently available at the exchange
SOADSL is restricted at the exchange
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for IPstream is from 31 Jan 2016. The Formal Retirement date for IPstream is from 31 Dec 2016.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Mildenhall exchange:Only single order products are available and ADSL and ADSL2+ products are not shown as available.However for premises that can only be served by SOADSL, BT will continue to accept ADSL and ADSL2+ orders until SOADSL is available.
Thank you for your interest
UK Speedtest Link:
https://www.thinkbroadband.com/speedtest/1661955388280282355
Shows download as 1.51Mbps (which I cannot get)
Generally tech savvy and can see no problems my end. I understand I am in a difficult area but nevertheless this is ridiculous.
Thanks! What does the SH's Status page show?
This is a quick overview of your EE Smart Hub's status.
Connection status: Connected
Broadband type
Fibre
Firmware version:
v0.06.01.08190-EE
Firmware updated:
Serial number:
Downstream sync speed:
5.20Mbps
Upstream sync speed:
801.00Kbps
Network uptime:
0 Days, 3 Hours, 33 Mins
System uptime:
0 Days, 3 Hours, 36 Mins
The observed speeds on the BTW suggest you are back on ASDL, the Technical log from the advanced pages from the router would confirm this.
Either way you are going to need an egineer to get it fixed, so the sooner you report a fault to CS the better.
You are getting ADSL speeds from Fibre. You are not on ADSL; both the SH Status page & the BTw Checker confirm you are on Fibre, with an expected speed of at least 60 Meg, having moved from ADSL probably in July 2021.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Are the speeds any better?
