Downgrade Broadband
openworld1
How do I go about downgrading the broadband package I have?  It's too expensive to pay now.
Thanks.
You can't downgrade to a cheaper plan mid-term, but only in your upgrade window from 30 days before end of term.
6 REPLIES 6
Matt_124
Hi @openworld1
As stated by @XRaySpeX above, you would be unable to downgrade to a lower price plan within your minimum term.
The only exception to this is for customers who would be eligible for BT Group's Social Tariff - BT Home Essentials - if in receipt of certain benefits. Eligible customers on BT or EE would be able to switch to this at any time. There is a number listed on the website to call for EE Customers.
You can find all of the related info here: https://www.bt.com/broadband/home-essentials
moscab1
my contract is ending on the 2 Nov 2025,
I have been offered same broadband speed (900Mbps) as I have now but a bit cheaper.
However I cannot see lower broadband speed available to select, such as 500Mbps.
Is there any reason why I couldn't downgrade?
Peter_W
Hey @moscab1.
Welcome to the EE Community!
We don't have access to accounts via these forums to check over the exact upgrade options available to you, but if you're out of contract you should definitely be able to look at a range of speeds.
I'd recommend giving our team a call, and they'll be able to make sure we take a look into everything that we can offer in your area.
Peter
I am in the period before end of term so can change. However, EE are not offering either the same prices for a new customer or providing the offer to downgrade to a lower package.
I am not sure that is ethical from a price perspective or restricting choice
Rach_H
Hi @badgerhead27,
Welcome to the Community!
We want to find you the perfect plan, so it may be worth reaching out to our team, and they will be able to look into your options and find a plan that works for you.
Rach
