DNS Settings Missing on Smart Hub Pro Wifi 7
ByAlex
I'm using the EE Smart Hub Pro (WiFi 7 model) with firmware version r2.64.7-R-1303938-PROD-1.
I'm trying to change the DNS settings to use something like Google DNS or Cloudflare, but I can't find any option in the router interface to do this. I've checked through both the web admin panel and the My EE app, but no luck.
Has anyone managed to find this setting or know if it's currently disabled or restricted in this firmware version?
Any help would be appreciated.
Thanks.
Is it not near the foot of the Advanced > My Network > IPv4 Config page? It is on the SH+.
Ewan15
Expert Contributor
Expert Contributor
@XRaySpeX The firmware on the Pro router is a few versions behind the Plus so whilst you can search for DNS and it is listed, you cannot get to it at the moment.
