Cannot load EE Smart Hub Management Home Page
freddy2004
Valued Contributor
Valued Contributor
Cannot load Hub management Home after running for a few days, the only way out is to restart! This is not acceptable.
22 REPLIES 22
@alwoods The chop-800 error was very prolific on the oob FW version 2-3 updates back and with the version that you reported have not seen it in eons, have you tried another device if you have it, like your mobile, or possible safari as you are a mac user.
alwoods
@JimM11 Doesn't work on any of them unfortunately (a router reboot does fix the problem but there definitely seems to be some issue there).
Safari Macbook
Safari iOS
iOS iPhone 15
@alwoods Are you a fully apples only person? Note below how the router FW has progressed recently.
FW: r1.35.0-R-1138091-PROD-83002 and the gui is at App version: 1.13.1.
FW: r2.68.11-R-1260390-PROD-83002
FW: r2.68.12-R-1270837-PROD-83002 and the gui is at App version 2.36.4.
FW: r2.68.16-R-1296172-PROD-83002 and the gui is at App version 2.36.4.
