13-11-2023 07:15 PM
Cannot connect wireless HP 4130e printer to my network asking for the pin no n the bottom of the router this is not available therefore printer will not connect.
Any ideas/help much appreciated
13-11-2023 07:52 PM
Which router? There will be no PIN written on any label on it but there might be amongst its settings.
Does the printer have a WPS button? Can you see the router's SSID in the list of available networks the printer sees?
13-11-2023 08:37 PM
Thanks for your reply, cannot see router in Network however I can see SSID, this will not connect the printer?
13-11-2023 10:56 PM
It will if you provide the router's WiFi pwd, if you are seeing SSID at the printer's end.
