Broadband Speed
Mlrb
Hi all,
I was wondering if it was normal to lose around 30Mbps on WiFi.
My Pc that is connected to the Hub gets around 68-70Mbps while my Laptop gets around 38-40Mbps even sat in the same room as the Hub.
@Mlrb  A wired connection will always be faster than WiFi. It’s wired to the router.  WiFi has to contend with other electronic devices in the room. that can cause interference ie a TV for example
thanks for the reply, the only other electronic device in the room was the TV and that is switched off at the plug unless in use, so I don't think its that. I switch off all electronic at the plug if I'm not using them.
I have also checked my mobile and that is running at the slower speed also, with my last provider I never had this massive drop to WIFI.
Thanks for the reply
2. Try both a wired & wireless speedtest here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
