Britbox router
getyers
My bribox looses internet so unplug and plug back in to reset it, also wifi not very strong to connect to my firestick 4k which is 10ft away from the router
My Brightbox 2 connects OK to my Roku Streaming Stick (similar to a Firestick) which is upstairs on the opposite side of the house.
