BT modem
Est_Elixir
My router seems to be an issue since migrating from BT to EE. My issue is associated with access and often It cuts out entirely. Are there any way that I can improve my network?
Brilliant Contributor
@Est_Elixir You do not say what you have equipment wise, so quickest way would be to contact EE CS and have them run a diagnostic to your system if they can do so to see if there are any apparent faults.
Mustrum
@Est_Elixir   you have not given very much  to go on, and no one on here has account access. Why not follow the steps in the help pages and get your issues looked at.
Contact us about your broadband and landline
Text EE for a call back
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
  1. We’ll run tests on your connection to find out what’s going on.
  2. If you need an engineer, we’ll text you in 15 minutes to book a slot.
  3. If you don’t need an engineer, we’ll call you within 30 minutes to help solve your issue.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
Call us
From your EE mobile
150
From any other phone
0330 123 1105
Calls are free from an EE number. Charges may apply if you call from another network.
Support for Deaf and hard of hearing customers
Text relay
To use the text relay service from your smartphone, PC or tablet, download the free Relay UK app.
To call us through the Relay UK app or from a textphone, dial:
18001 07953 966 150
Sign language services
If you need the support of a British Sign Language (BSL) interpreter, you can contact us through the InterpretersLive! service.
Connect to a BSL interpreter
Est_Elixir
Solution found! The QR code at the back of the modem doesn’t match the name of the Wifi! I believed a troll had changed this for some giggles!
@Est_Elixir   Not a troll, but you probably did that yourself! The app changes the default router SSID if you ask it to migrate your old settings, so I prsume the settings are the same as your old router?
But glad you got it sorted, thanks for updating us.
QR codes, linking router with app & WiFi SSIIDs have absolutely nowt to do with the router's performance & cutting out. So I'm nor clear what problem has been solved.
