BT Premium AX3700 Triband Mesh - Wifi 6
monkeychunki
Hi, i recently purchased the Premium mesh to replace the Mercusys Wifi 6 that i had. I've connected it all up to my EE Smart Hub Plus wifi 6 hub and I cant get the mesh to push out 802.11ax, only wifi 5 802.11ac on my wifi 6 compatible devises.
Peter_W
Good morning @monkeychunki.
Welcome to the EE Community 😊
I can see you've posted about this over on the BT Forums too.
I'd definitely recommend checking out the advice Keith mentions in his most recent post, as fingers crossed the BT Product team should be able to take a closer look into things for you.
Peter
Maestro
Maestro
@monkeychunki You may wish to check this review, were it states, wifi 6 is for backhaul only, cannot find relevant BT specs anywhere.
BT Whole Home Wi-Fi Review: With Wi-Fi 6 & Premium Wi-Fi Options
