Apple TV connectivity issues with Smart Wifi Pro
TraderTravel
First up I should state that I have reported the issue posted below to EE Customer Services, but I thought it worthwhile posting here in case others are searching.
I have a new service connected (1.6gbps service) with a Smart Hub Pro and multiple Smart Wifi Pros. I thankfully have an ethernet network plumbed in, so all the Smart Wifi Pros are connected via ethernet directly back into the Smart Hub Pro.
What I have noticed is that if you connect an Apple TV to the Smart Hub Pro via the second ethernet socket on the Smart Hub Pro, you will experience connectivity issues and speed issues (speeds drop down to 100-150mbps when measured using the SpeedTest app). Connectivity issues range from apple authentication issues to a few other odd gremlins. If I place a switch inbetween the Smart Hub Pro and the Apple TV, the speeds go back up to maximum (1gbps), and the connectivity issues disappear, so the software/firmware issue seems to be directly correlated to having the Apple TV directly connected to the Smart Wifi Pro using ethernet.
I have been able to replicate the issue with multiple Apple TVs and multiple Smart Hub Pros, so the issue definitely seems to be a software/firmware related issue - it is not a hardware issue. Plugging an Apple TV directly into the router (Smart Hub Pro) does not exhibit the issue, so it is only via the extenders.
Hopefully the issue will be fixed in a future update, although it does make me wonder whether any other devices experience issues when connected to the Smart Wifi Pro via the ethernet socket.
21 REPLIES 21
norwoody
@JimM11 cheers for the tip. Actually not long after posting that I powered down the Smart Wifi Pro Extenders, rebooted the Smart Hub Pro (Router) and left the extenders off for about an hour or so. I then turned the extenders back on one by one and so far speeds seem to be in range with what I'm expected both wired and wireless.
I'm not sure what's going on but the ethernet issues with the mac mini and the slow wifi seems to have gone for now but it doesn't look like I've had a firmware update or anything and I've changed nothing else in my network.
@norwoody The last Pro FW update was way back in Feb25 as far as user's had posted then was at that time, the details below just incase you need to compare, anything different may be newer, there are NO dates, i add that as ref when first seen Forum wise just so you know! All you can do is keep the eye on it and see how it all behaves!
FW: r2.64.7-R-1303938-PROD-1 and the gui is at App version 2.34.2. 07/02/2025
wenklaw
Yep I’m seeing issues with wired backhaul speeds degrading over 24 hours to around half what it should be, approx 400mbps.
And I’m also unable to connect to my openvpn  host I have running on my NAS (on the same network)  if the device trying to connect is connected to the EE WiFi pro.  If the device is connected to the EE router it can connect to my OpenVPN host no problem.  Now this isn’t particularly important BUT devices SHOULD be able to connect via the EE WiFi pro and always have been able to when I have used other MESH devices via a wired backhaul.
Something seriously wrong with the EE WiFi pro IMO
norwoody
@JimM11 yeah I have the same versions on my Smart Hub too. Though I did see some mention of a new version that allowed for setting DNS servers as part of DHCP?  Or maybe that was for a different EE router model, it’s difficult to keep up with the naming conventions.
@wenklaw interesting that you mention the degradation happens over 24 hours, I’ll check my network again later tonight to see if I notice the same.
@norwoody EE Smarthub+ implemented now last release of there FW update, Pro in the future who knows! One follows other follows other but never together, lot's going on no doubt!
TraderTravel
I see the issues as soon as I connect an Apple device (natively) to the EE Wifi Pro (i.e. extender). Just to reiterate, Apple TV seems to drop from 1gbps down to 100-150mbps when connected via the extender. The extender itself is connected to the main Smart Hub Pro via ethernet backhaul. If I disconnected the extender and plug the Apple TV into the ethernet which connects to the Smart Hub Pro, I get the full 1gbps again.
I've been able to duplicate this behaviour on two different Apple TVs, and on two different Smart Wifi Pros (extenders).
Personally I don't like running Apple TV on anything but ethernet, as a TV never moves and it always likes to hog bandwidth. If you have multiple people watching TV in different rooms, directing that traffic down ethernet makes sense.
My key issue is not the just the drop in speed, but more importantly the fact it does appear to be dropping packets as I get authentication issues etc. Considering all the traffic is staying on the wire, this should not be happening.
That's for the the Smart Hub Plus now @ f/ware level r3.8.11-R-1414606-PROD-83002 , not the SH Pro.
@TraderTravel Do you have a spare or old 1Gb/s switch lying around that you could try in between the Apple TV and the Spare nic port on the Extender where you currently have the Apple TV currently connected!
TraderTravel
As you will see above @JimM11 , clearly I do, as I am able to test the difference in speed between an Apple TV directly connected to the Smart Wifi Pro (extender) via ethernet, and that of a device connected via a Switch. I don't however believe I should have to use an additional switch just to get the thing to work. 🙂
@TraderTravel The should or should not you are correct, best look to your own gear then and not rely on EE equipment!
