10-06-2021 10:17 AM
Hi
I recently had an automatic update on my phone. The reverse camera has stopped working ever since. it will let me take pictures but only with the front camera. I understand that this has happened to a lot of others pixel 3a users aswell. does anybody know if this has been resolved yet. Thanks
10-06-2021 10:34 AM
@Angenorth have you tried doing a factory restore on the device ? obviously back up the device 1st to make sure you keep your information.
10-06-2021 11:12 AM
yes ive done a reset. when i open the camera it says there was a problem opening. and that there may be a problem with the hardware/software
10-06-2021 01:01 PM
Hi @Angenorth.
Can you open up the camera at all, or do you get this error when you try to open the camera?
Was this just a regular software update?
Jon
14-06-2021 03:12 PM
I can only open the camera for selfies, it wont let me flip to the other camera. and yes it started doing this after a automatic update
14-06-2021 03:33 PM
Thanks @Angenorth.
Do you get any error message when you try to flip the camera?
Is there another update to be done, or are you now on the latest software?
Jon
15-06-2021 05:09 PM
Does this still occur when the handset is in safe mode? Not being able to launch and use the rear camera?
Are you using any 3rd party camera apps from the Play store?
