03-03-2021 09:48 AM
I am trying to use EE 4G SIMs on mobile CCTV streaming DVRs. The device will work on UK networks that support WCDMA FDD LTE. I have no issues using O2 but i cannot get comms working on EE. Any ideas
03-03-2021 11:37 AM
Assuming the Device is SIM and Network Free have you checked or changed the APN Settings in the Device to match the EE APN Settings.
03-03-2021 11:55 AM
Yes the device sim free. I have put the correct APN details in. The device works as i said with O2 4G. The device manufacturer wants to clarify is that the EE network WCDMA FDD LTE which i believe it is. I may have to talk to EE technical to get the answer.
03-03-2021 12:02 PM
EE as all the 4 UK Networks are WCDMA and FDD LTE, Or in better terms 3G and 4G.
03-03-2021 12:05 PM
Thanks for the confirmation, you know when you are dealing with some suppliers they will not always accept your first answer and always want another confirmation. My belief is there is a problem with their device now i have the uphill battle with them 🙂
03-03-2021 12:08 PM
What's the Device, and what Bands does it support, are you in good EE Coverage.
03-03-2021 03:37 PM
It's also worth being aware, EE have refarmed extensive amounts of spectrum that was previously used for 3G services, and is now 4G.
Whilst no 3G coverage has been (or is being) removed, the quantity of spectrum is now down to 5Mhz in many areas, which will restrict the speed of streaming services.
