close
Using watch data as hot spot
Profile closed
Not applicable
The watches have unlimited data. I know I can't share the data but can use the watch as hotspot with the data
@Profile closed   How do you intend to connect a device to it to use the watch data ?  There isn’t a hotspot feature on the watch and the Bluetooth connection doesn’t work that way.    Not to mention you’ll kill the battery if this was even possible.
Profile closed
Not applicable
I INTEND to ask the forum because I don't have the watch and wanted to see if its an option if I purchased one.
Saying it kills the battery isn't an issue. Using the flashlight on my phone kills the battery but ill use if I need it a pinch so I don't need you tell me that it'll kill the battery as If I'd be using it as a daily hotspot.
James_B
EE Community Manager
Hi @Profile closed,
No, the Apple Watch doesn't have a hotspot feature.
