close
Upgrade and downgrade
1699226
Hi guys! My package is pay as you go  - 5Gb. I would like to upgrade to  pay as you go - 100 gb (£30). So the question is: will I be able to downgrade back for free at any time? Thank you.
On PAYG you may switch between Packs as much as you like, up, down or even stop altogether. Just buy your next pack just before your current 1 expires & it will kick in as soon as it does OR you can even buy it early & make it start immediately by texting NOW to 150.
