27-09-2020 09:00 AM
I have a tablet which we haven’t used for some time and none of the family can remember what we set the pin as to unlock it. Is there a way of resetting the device back to factory settings without knowing the pin.
thanks
27-09-2020 09:02 AM
No factory reset I'd the o my way if you can't remember the pin.
27-09-2020 09:09 AM
27-09-2020 12:12 PM
Hi @Shelley8.
You can try to reset it, but most devices will require you to enter the pin to be able to complete the reset.
What make/model is it?
Jon
