07-10-2020 01:12 PM
Is it possible to unlock a device that hasn’t been on contract for 6 months yet, as I have an iPhone 11 which is currently locked and I am struggling to unlock it, I’ve attempted to unlock it through the my ee app but it just says my device can’t be unlocked - that’s it no explanation as to why.
07-10-2020 01:15 PM
@1taib : No, EE own it for the 1st 6 months during which you cannot alter its state.
07-10-2020 01:31 PM
I'm not currently paying monthly, and I have a normal pay as you go sim inserted, does this change anything at all. Or do i just have to wait 6 months.
07-10-2020 01:47 PM
No, @1taib , if you bought the phone directly from EE as PAYG, you can have it unlocked immediately.
However it's not a matter of what type of SIM you are using in it currently, but on how you bought the phone from EE. You never said. For all I know you could have bought a 2nd-hand phone & put an EE PAYG SIM in it. That's a diff kettle of fish.
07-10-2020 02:03 PM
I see, the phone was given as a gift, I haven't asked them where they had gotten it from, so I'll definitely do that. If they say they bought it for a pay monthly plan its locked for 6 months correct me if I'm wrong? I apologise for asking the same questions and being repetitive, i'm not very educated in this field. Thanks for your help
07-10-2020 02:09 PM
@1taib : Yes, as far as EE is concerned it is a 2nd-hand device in your hands & how it was originally bought, on contract or PAYG, will determine whether you need to wait 6 months or not to get it unlocked.
31-01-2021 01:20 PM
After a device reaches 6 months of age, what is the process to unlock it?
31-01-2021 02:36 PM - edited 31-01-2021 02:38 PM
@1taib : That depends on how you obtained it. That's not clear from your previous posts. 1 min. it was on your contract for less then 6 months, the next it was a gift.
Where did you yourself get this device itself originally? Did you buy it yourself new direct from EE or from a 3rd-party reseller or is it 2nd-hand? The unlocking process & costs are different. Was it originally on contract or PAYG? How old is it? EE won't unlock contract devices less than 6 months old.
31-01-2021 02:44 PM
The phone will reach 6 months of age in a few days, I just wanted to know how I would be able to unlock it when it reaches that age, as you are saying the way I obtained it is significant the person who gifted it doesn’t remember whether it was on contract or not, but it is locked as only EE sims are supported in the phone. Is it possible for the phone to be permanently locked?
31-01-2021 03:02 PM
No, they can always be unlocked, either through EE or a third party service
