No notification sounds or ringing pixel3
Ippingstock
8 REPLIES 8
@Ippingstock   Is the device on mute ?
Northerner
Hi @Ippingstock
Have you increased the notification volume.
Ippingstock
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
It just stopped one day.notigications only works with headphones.not on mute and volume on full and have turned off and cleaned phone jack
Cheers
James_B
EE Community Manager
Hi @Ippingstock,
Does your phone's speaker work when playing media etc?
Yes.doesnt ring..so miss calls.does not notify .but does work with Bluetooth.cheers
James_B
Hi @Ippingstock,
If the speaker is working, it may just be an issue with your sound/notifications settings.
Do you make sure your Bluetooth accessories are disconnected when not in use?
Have you made sure the notification volume is turned up, rather than just the media volume?
Done all that, nothing happens.literally.one day fine...next nothing... with no change of settings
James_B
Hi @Ippingstock,
Does the phone still vibrate when you get a notification?
Do you have a sound selected in Settings > Sound > Advanced > Default notification sound
