close
Forgotten lock screen pattern
AdsAfz
Hi
I've recently purchased a Samsung S21 and use my fingerprint to unlock and use my phone.
However, I have forgotten the lock screen pattern which is needed if I were to switch the phone off/on.
My fear is that if my phone were to be reset of turned off, it would become inaccessible.
Any ideas on how I can change/remove the pattern?
James_B
EE Community Manager
Hi @AdsAfz,
You can also unlock your phone remotely using Find My Mobile. For more details, please see www.samsung.com/uk/support/mobile-devices/i-cant-unlock-my-device/.
Hope this helps.
9 REPLIES 9
If you've forgotten your unlock pattern you'll need reset your phone & lose all your data.
Thanks for your reply. Are you saying I need to reset even though I can,
access my phone via fingerprint? Thanks
Go into settings and change your pattern. It should only ask you for your fingerprint for security.
BrendonH (Android Expert) Google Pixel 8 Pro Obsidian Black (Android 15)
If that don't work go and change the unlock security to nothing and then out back to fingerprint it'll ask you how you want the backup unlock again and you can choose a pattern again.
Hi BrandonH
It asks for my current pattern, allows me to make one attempt and then
makes me wait 30 seconds before I can make another attempt.
I have to enter the current pattern first. Otherwise I don't get any
options.
James_B
Hi @AdsAfz,
Hope this helps.
Thanks @James_B. You're an absolute life saver.
When I went to the URL the instructions were so explicit. Searching Google and YouTube was of no use in finding a resolution.
James_B
No problem @AdsAfz 🙂
