close
Data Allowance Offers
Romford
I can't find the TV offer of 150GB for £20 anywhere on My EE. Also why can't I just upgrade my data allowance plan without changing my phone ?
@Romford : Here it is in the Shop: Pay Monthly SIM Only Deals . It's for a new contract SIM.
You may always change your existing plan mid-term to a more expensive 1 with more data.
mikeliuk
Hi @Romford ,
If you use the Usage link below, do you see an option to "Change plan"?
In my case, I can go from 200 GB a month to unlimited data for £3.21/mth. I would recommend to check the terms and conditions as discounts may drop off and you may lose things you want in your current plan (Amazon Prime Video in my case).
The other option is a SIM-only upgrade once you are eligible but you may need to pay a certain amount to own your device, if you do not already own it, or may be able to trade it in to pay less.
