close
Checking data usage on 4GEE router
FMacD
Just started using a 4GEE router in a rural location but I really need to know how to check my data usage before my 14 day 'test' period is over. Can't find any way of doing that. Any suggestions? Being able to check data usage is very necessary,,,
I said "page" not "link" meaning somewhere in its management pages should be some stats on data usage.
On my EE mobile router I login to it at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then under the Connection tab is Connection Status / Usage History
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
There should be a data usage page in it. Also iook at http://add-on.ee.co.uk/status from a device connected to it by WiFi to see your data & credit status.
Thanks. That link did the trick. But when you say there should be a data usage link in it, I don't get where you mean... Can you clarify for me please and excuse my being a bit dim. Thanks
That’s great. I now know the router intimately, and more to the point, my data,
That's good! That's worth knowing!
