12-08-2020 08:40 PM
Hello!! I was cleaning out my earpiece with blue tac and managed to do so. But like an idiot I decided to give it one more go and, unfortunately for me, blue tac got stuck 😭😭😭 I got as much as possible out but there's still some stuck. Does anyone have any suggestions on how to get rid?? Also, just incase...How much does it cost to clean a Huawei mate 20 pro earpiece? I did this because my phone calls became slightly quiet.
13-08-2020 07:59 AM
@Ihsan_974 You’ll not get a cost price to fix this until the device has been looked at then you’ll be told how much it will cost.
As for trying to clear this yourself you could try using a pin but be very careful when doing this as you could damage something yourself and it’ll cost more to fix. You’ll need to use a magnifying lens to see what your doing on something so small.
That is only a suggestion and you undertake this at your own risk.
26-08-2020 06:54 PM - edited 26-08-2020 06:57 PM
What about a toothpick? Or some type of Sewing Needle or extra/long fine pin (maybe not the sharp end of that)? All at your own risk.
